HP Pavilion - 15-cs0078ur Product Specifications
5GW80EA
Intel® Core™ i3-8130U (2.2 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB DDR4-2400 SDRAM (2 x 4 GB)
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
Pointing device
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB Type-C™ 3.1 Gen 1 (Data transfer only, up to 5Gb/s); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI 1.4; 1 RJ-45; 1 headphone/microphone combo
36.16 x 24.56 x 1.79 cm
1.93 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 30 minutes
Video Playback Battery life
Up to 9 hours and 30 minutes
FreeDOS 2.0
