5SE68PA
HP Pavilion 14-ce1064tx
Intel® Core™ i7-8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
14" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo
1 HDMI 1.4; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ (Data transfer only, 5 Gb/s signaling rate)
32.68 x 22.17 x 1.79 cm
1.6 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion 14-ce1064tx Product Specifications
HP Audio Switch; HP CoolSense; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant; HP Connection Optimizer
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
