    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-db0053nv Product Specifications
5MK93EA
AMD A6-9225 Dual-Core (2.6 GHz base frequency, up to 3 GHz burst frequency, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
  • AMD Radeon™ 520 Graphics (2 GB GDDR5 dedicated)
  • Discrete
500 GB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA anti-glare WLED-backlit (1366 x 768)
Pointing device
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI 1.4b; 1 RJ-45; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
2.04 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 15 minutes
Video Playback Battery life
Up to 7 hours and 30 minutes
HP Webcam with integrated digital microphone
Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
