    Fix Windows 10 Update Issues
    Are you working from home?
HP Spectre x360 - 13-ap0008ur Product Specifications
5MJ00EA
Intel® Core™ i7-8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB DDR4-2400 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
1 TB PCIe® NVMe™ M.2 SSD
33.8 cm (13.3") diagonal 4K IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (3840 x 2160)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® Wireless-AC 9560 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 Combo (Gigabit Wi-Fi® speed)
1 microSD media card reader
2x USB Type-C™ 3.1 Gen 2 (Thunderbolt™ 3, DP 1.2, PD 3.0, Data transfer, HP Sleep and Charge ); 1x USB 3.1 Gen2 Type-A™ (HP Sleep and Charge); 1 headphone/microphone combo
30.88 x 21.79 x 1.47 cm
1.33 kg
65 W AC power adapter
4-cell, 61 Wh Li-ion
Battery life mixed usage
Up to 14 hours and 30 minutes
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP Connection Optimizer; HP JumpStart
