    Fix HP Printer issue on macOS
HP Spectre Folio - 13-ak0022tu Product Specifications
5UE34PA
Intel® Core™ i5-8200Y (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 615
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB Type-C™ 3.1 Gen 1 (Data up to 5 Gb/s, Power Delivery, DP 1.2, HP Sleep and Charge); 1 headphone/microphone combo
32.01 x 23.45 x 1.54 cm
Starting at 1.47 kg
65 W USB Type-C™ adapter
6-cell, 54.28 Wh Li-ion
Bang & Olufsen; quad speakers; HP Audio Boost 2.0
Windows 10 Pro 64
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
McAfee LiveSafe™ 30-day free trial offer
Pre-installed software
iQiyi
