HP Pavilion 15-cs1069tx Product Specifications
5NL23PA
Intel® Core™ i5-8265U (1.6 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Pointing device
1 HDMI 2.0; 1 headphone/microphone combo; 1 RJ-45; 2 USB 3.1 Gen 1 (Data transfer only); 1 USB 3.1 Type-C™ (Data transfer only, 5 Gb/s signaling rate)
36.16 x 24.16 x 1.79 cm
Starting at 1.85 kg
120 W AC power adapter
4-cell, 68 Wh Li-ion polymer
HP Audio Switch; HP CoolSense; HP Documentation; HP ePrint; HP JumpStart; HP Support Assistant; HP Connection Optimizer
