Document ID: c06111259
Version: 1
Advisory: Elite Slice for Meeting Rooms G2 SRS - Buttons and LEDs on the Communications Top Stop Working After Updating Skype Room Systems Software
Release date : 09-Aug-2018
Last updated : 10-Aug-2018
DESCRIPTION
The call status LEDs on the Communications Top no longer show call status and the call buttons stop working. Only the volume control buttons work. This occurs after Skype Room Systems (SRS) has been updated to version 4.0.8.0.
NOTE: The issue does not affect the Center of Room Control. Call and status functions on the CoRC still work normally.
SCOPE
Systems:
  • Elite Slice for Meeting Rooms G2 for Skype Room Systems (P)
Operating Systems:
  • Microsoft Windows 10 IoT (64-bit)
RESOLUTION
To resolve this issue, perform the following steps:
  1. Open Device Manager.
  2. Locate and expand the Human Interface Devices section.
  3. Locate the Slice Collaboration Cover device.
  4. Right-click and select Update driver.
  5. Select Search automatically for updated driver software and wait for the driver to download and install.
  6. Locate the HID Telephony for Slice device.
  7. Right-click and select Update driver.
  8. Select Search automatically for updated driver software and wait for the driver to download and install.
  9. Confirm the driver version is updated to version. 1.0.1.123.
Hardware platforms affected : HP Elite Slice for Meeting Rooms G2 for Skype Room Systems
Support Communication Cross Reference ID : IA06111259
