HP EliteDisplay S14 Portable Monitor Specifications
Product image
Figure : HP EliteDisplay S14 Portable Monitor
Panel
Specification
Display panel type
14 inches IPS, LED backlight
35.56 cm (14 in) widescreen
Panel active area (W x H)
309.31 x 173.99 mm (12.18 x 6.85 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
160° minimum, up to 178° horizontal (10:1 minimum contrast ratio)
160° minimum, up to 178° vertical (10:1 minimum contrast ratio)
Brightness (typical)
200 cd/m2
Contrast ratio (typical)
Static
700:1
Dynamic Contrast Ratio (DCR)
5,000,000:1
Response times
25 ms
Default is 25.0 ms and can be adjusted to as low as 5 ms in the display menu. See user guide for more information.
Pixel pitch
0.1611 x 0.1611 mm
Pixel Per Inch (PPI)
157
Default color temperature
Neutral (6500 K)
Backlight lamp life
15,000 hours minimum (to half brightness)
Color support
2,62,144 colors
Color gamut (typical)
45% (NTSC)
Anti-glare panel
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Plus ("+")
Minus ("-")
Exit ("X")/Return
Power
User-assignable function buttons
11
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset VESA graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 1050 at 60 Hz
Pixel clock (maximum)
170 MHz
Vertical frequency
Up to 60 Hz
Horizontal frequency
Up to 80 kHz
Video/other inputs/cables
Specification
Connector types
(1) USB Type-C
Cables
(1) USB Type-C 1.8 m (5.9 ft) cable
Ergonomics
Specification
Plug and play
Yes
Color
Exterior color of monitor bezel and stand
Ebony black
Power
Specification
Input power
5 V
Maximum power
7 W
Maximum power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Typical power
5 W
Default power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
Energy saving/standby mode
0.3 W
Physical specifications
Specification
Dimensions (W × D × H)
Packaged (box)
Box: 39.40 x 6.30 x 28.40 cm (15.51 x 2.48 x 11.18 in)
Packaged (carton)
Box: 43.0 x 35.10 x 32.79 cm (16.93 x 13.82 x 12.91 in)
Head only (unpacked without stand
32.79 x 0.86 x 20.93 cm (12.91 x 0.34 x 8.24 in)
Packaged
1.9 kg (4.2 lb)
Head only
1.0 kg (2.20 lb)
What's in the box?
Specification
Monitor and accessories
HP EliteDisplay E243m 23.8-inch Monitor
USB 3.0 Type-C cable
Other contents
Documentation
HP Display Assistant
Environmental
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95% (38.7°C maximum wet-bulb)
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free LED display backlighting
Yes
Low halogen
Yes
Eco-label certifications & declarations
ENERGY STAR (7.0)
EPEAT Silver (registration varies by country/region)
Microsoft WHQL certification (Windows 7, 8 and 10)
SmartWay transport partnership (North American countries/regions only)
BSMI
CE
CB
CSA
CCC
EAC
FCC
ICE
ISO 9241-307
KC
KCC
TUV-S
UL
VCCI
WEEE
WW application
