OMEN by HP - 15-dc0030nr Product Specifications
3WE66UA
Intel® Core™ i7-8750H (2.2 GHz base frequency, up to 4.1 GHz with Intel® Turbo Boost Technology, 9 MB cache, 6 cores)
16 GB DDR4-2666 SDRAM (1 x 16 GB)
Video graphics
NVIDIA® GeForce® GTX 1060 (6 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size 4-zone lighting backlit keyboard with numeric keypad and NKRO
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 headphone/microphone combo; 1 microphone-in; 1 Mini DisplayPort™; 1 RJ-45; 1 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge);
36 x 26.3 x 2.6 cm
2.52 kg
200 W AC power adapter
4-cell, 70 Wh Li-ion
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer;
Pre-installed software
Netflix
