    Fix HP Printer issue on macOS
HP Pavilion - 15-cs0106tx Product Specifications
4SZ30PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal HD SVA BrightView micro-edge WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI 1.4; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer Only); 1 RJ-45
36.16 x 24.16 x 1.79 cm
Starting at 1.85 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
McAfee LiveSafe™ 30-day free trial offer
