HP 25x 24.5-inch Display - Product Specifications
The HP 25x is a 62.23 cm (24.5 in) Display.
Figure : HP 25x 24.5-inch Display
The HP 25x 24.5-inch Display
Product numbers
3WL50AA, 3WL51AA
Technical specifications
LED feature
Specification
Display size
62.23 cm (24.5 in) diagonal with micro-edge bezel
Display type
TN with LED backlight, anti-glare
Panel active area
54.38 x 30.25 cm (21.41 x 11.91 in)
Brightness
400 nits
Color gamut
72% of NTSC
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.283 x 0.280 mm
89.7 PPI
Inputs
1 DisplayPort (DP)
1 HDMI
HDCP supported on DP and HDMI.
Viewing angle
Horizontal viewing angle: 170 degrees
Vertical viewing angle: 160 degrees
Scan range
Horizontal: 30-167 kHz
Vertical: 48-144 Hz
Recommended resolution (H x V)
1920 x 1080 at 60 Hz (FHD)
Full high-definition (FHD) content required to view FHD images.
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 12,000,000:1
Response time
1 ms gray-to-gray (GtG) with overdrive
Actual performance might vary.
Power consumption
32 Watts maximum
Tilt
-4 to +20 degrees
Power supply
Internal
Dimensions
W x D x H (unpacked):
55.72 x 20.65 x 49.25 cm (21.94 x 8.13 x 19.39 in)
Unpacked: 5.72 kg (12.61 lbs)
