    Fix Windows 10 Update Issues
    Are you working from home?
HP Chromebook - 14-ca030nd Product Specifications
4RD94EA
Intel® Celeron® N3350 (1.1 GHz base frequency, up to 2.4 GHz burst frequency, 2 MB cache, 2 cores)
4 GB LPDDR4-2400 SDRAM (onboard)
Video graphics
Intel® HD Graphics 500
32 GB eMMC
14" diagonal FHD IPS anti-glare WLED-backlit edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 headphone/microphone combo
33.7 x 22.7 x 1.83 cm
1.53 kg
45 W AC power adapter
2-cell, 47.36 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
B&O PLAY, dual speakers
Chrome OS™
