    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP EliteDesk 800 G4 Workstation Edition Specifications
Product image
Figure : HP EliteDesk 800 G4 Workstation Edition
Operating systems
Specification
Pre-installed (Windows)
Windows 10 Pro 641
Windows 10 Home Single Language 641
Windows 10 Home 641
Windows 10 Pro 64 (National Academic License)2
Pre-installed (Other)
FreeDOS 1.2
Web-supported only
Windows 10 Enterprise 641
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
2Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-8700 processor
3.2 GHz (up to 4.6 GHz with Intel Turbo Boost technology)
12 MB cache, 6 cores
Intel UHD Graphics 630
Supports Intel vPro Technology
Intel Core i7+ 8700 processor
Core i7 and 16 GB Intel Optane memory
Intel Core i7-8700K processor
95 W
Up to 3.7 GHz
Intel Core i7+ 8700K processor
2.4 GHz (up to 3.7 GHz with Intel Optane memory)
Intel Core i5-8600K processor
95 W
Up to 3.6 GHz
9 MB cache, 6 cores
Intel Core i5+ 8600K processor
Core i5 and 16 GB Intel Optane memory
3.1 GHz (up to 4.3 GHz with Intel Turbo Boost technology)
9 MB cache, 6 cores
Intel Core i5-8600 processor
9 MB cache, 6 cores
Intel Core i5+ 8600 processor
9 MB cache, 6 cores
Intel Core i5-8500 processor
3.0 GHz (up to 4.1 GHz with Intel Turbo Boost technology)
9 MB cache, 6 cores
Intel Core i5+ 8500 processor
9 MB cache, 6 cores
Intel Core i3-8300 processor
3.7 GHz base frequency
8 MB cache, 4 cores
Intel Core i3-8100 processor
3.6 GHz base frequency
6 MB cache, 4 cores
Intel Pentium Gold G5600 processor
3.9 GHz base frequency
4 MB cache, 2 cores
Intel Pentium Gold G5500 processor
3.8 GHz base frequency
4 MB cache, 2 cores
Intel Pentium Gold G5400 processor
4 MB cache, 2 cores
Intel UHD Graphics 610
Intel Celeron G4900 processor
3.1 GHz base frequency
2 MB cache, 2 cores
Intel Q370 PCH-H—vPro
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Optane memory system acceleration does not replace or increase the DRAM in the system.
Intel Turbo Boost technology requires a PC with a processor with Intel Turbo Boost capability. Intel Turbo Boost performance varies depending on hardware, software, and overall system configuration.
Some functionality of vPro technology, such as Intel Active management technology and Intel Virtualization technology, requires additional 3rd-party software in order to run. Availability of future "virtual appliances" applications for Intel vPro technology is dependent on 3rd-party software providers. Compatibility of this generation of Intel vPro technology-based hardware with future "virtual appliances" is yet to be determined.
Memory
Specification
DDR4-2666
Maximum: 64 GB
Number of slots: (4) DIMM
Up to 2666 MT/s
Configurations
4 GB total system memory (4 GB x 1)
8 GB total system memory (4 GB x 2)
8 GB total system memory (8 GB x 1)
16 GB total system memory (8 GB x 2)
16 GB total system memory (16 GB x 1)
32 GB total system memory (16 GB x 2)
32 GB total system memory (8 GB x 4)
64 GB total system memory (16 GB x 4)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2666 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
All memory slots are customer accessible/upgradeable.
Graphics
Specification
Intel HD Graphics (integrated)
Intel Core i7 processor
Intel Core i5 processor
Intel Core i3 processor
Intel Pentium G5400 processor
Optional (discrete)
AMD Radeon RX550 4 GB 2 DP 1HDMI Graphics Card X AMD
AMD Radeon RX580 4 GB FH PCIe x16
AMD Radeon R7 430 2 GB 2 DP Graphics Card
AMD Radeon R7 430 2 GB VGA with DP Graphics Card
NVIDIA GeForce GTX 1060 3 GB Graphics Card
NVIDIA Quadro P400 2 GB Graphics Card
Adapters and cables
Specification
Adapters
HP DisplayPort to DVI-D adapter
HP DisplayPort to HDMI 4K adapter
HP DisplayPort to VGA adapter
HP USB-C to USB 3.0 adapter
HP USB to Serial port adapter
Cables
HP DisplayPort cable
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
2 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
2 TB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
Self-Encrypting drives (SED HDD)
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), Self Encrypted Opal 2 SATA
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), Self Encrypted Federal Information Prcoessing Standard (FIPS) SED
Self-Encrypting drives (SED SSD)
256 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), SED Opal 2
512 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), SED Opal 2
256 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), Federal Information Processing Standard (FIPS) SED
512 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), FIPS SED
Solid State Hybrid drives (SSHD)
500 GB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in), 8 GB hybrid
1 TB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in), 8 GB hybrid
PCIe NVMe M.2 SSD drives
128 GB, M.2 2280, PCIe NVMe SSD
256 GB, M.2 2280, PCIe NVMe SSD
512 GB, M.2 2280, PCIe NVMe SSD
128 GB, M.2 2280, PCIe NVMe TLC SSD
256 GB, M.2 2280, PCIe NVMe TLC SSD
512 GB, M.2 2280, PCIe NVMe TLC SSD
1 TB, M.2 2280, PCIe NVMe TLC SSD
256 GB, M.2 2280, PCIe NVMe SE Opal2 TLC SS
512 GB, M.2 2280, PCIe NVMe SE Opal2 TLC SS
2.5 in SATA SSD drives
SATA 128 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), TLC
SATA 256 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), TLC
SATA 512 GB, SATA 6.0 Gb/s, 6.35 cm (2.5 in), TLC
SATA 256 GB, 6.35 cm (2.5 in), Self Encrypted Opal2, TLC
SATA 512 GB, 6.35 cm (2.5 in), Self Encrypted Opal2, TLC
SATA 256 GB, 6.35 cm (2.5 in), Self Encrypted Federal Information Prcoessing Standard (FIPS)
SATA 512 GB, 6.35 cm (2.5 in), Self Encrypted Federal Information Prcoessing Standard (FIPS)
Optical disc drives (ODDs)
HP 9.5 mm Slim DVD-ROM drive3
HP 9.5 mm Slim DVD Writer drive 4
HP 9.5 mm Slim Blu-Ray Writer drive 5
Media card reader
SD 4.0 with 5-in-1 Interface (supports SD, SDXC, SDHC, UHS-I, and UHS-II)
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
3HD-DVD discs cannot be played on this drive. No support for DVD-RAM. Actual speeds may vary. Double Layer discs can store more data than single layer discs. Discs burned with this drive might not be compatible with many existing single-layer DVD drives and players.
4DVD-RAM cannot read or write to 2.6 GB Single Sided/5.2 GB Double Sided – Version 1.0 media.
5With Blu-Ray, certain disc, digital connection, compatibility and/or performance issues might arise, and do not constitute defects in the product. Flawless playback on all systems is not guaranteed. In order for some Bluray titles to play, a DVI or HDMI digital connection might be required and your display might require HDCP support. HD-DVD movies cannot be played on this desktop PC.
Do not copy copyright-protected materials.
Keyboards/pointing devices
Specification
Keyboards
HP USB Conferencing Keyboard
HP Wireless Collaboration Keyboard
HP USB and PS/2 Washable Keyboard
HP USB SmartCard (CCID) Keyboard
HP USB Business Slim Keyboard
HP USB Keyboard
HP PS/2 Business Slim Keyboard
HP PS/2 Keyboard
Mice
HP PS/2 Mouse
HP USB Optical Mouse
HP USB Premium Mouse
HP USB 1000 dpi Laser Mouse
HP USB and PS/2 Washable Mouse
Antimicrobial USB Mouse (not available in all regions)
HP USB Hardened Mouse (not available in all regions)
Combos
HP Wireless Business Slim Keyboard and Mouse
Networking/communications
Specification
Ethernet (RJ-45) (integrated)
Intel I219LM Gigabit Network Connection LOM (standard)
Intel Ethernet I210-T1 PCIe x1 Gb Network Interface Card (optional)
Wireless LAN
Intel 9560 802.11ac 2x2 Wi-Fi with Bluetooth M.2 Combo Card vPro
Intel 9560 802.11ac 2x2 Wi-Fi with Bluetooth M.2 Combo Card non-vPro
Realtek RTL8822BE 802.11ac 2x2 with Bluetooth M.2 Combo Card
Realtek RTL8821BE 802.11ac 1x1 with Bluetooth M.2 Combo Card
Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Audio/multimedia
Specification
Type
Conexant CX20632 Audio Codec (all ports are stereo)
2 W class D mono amplifier for the internal speaker only
Front: (1) Headset connector supports a CTIA style headset and is retaskable as a Line-in, Line-out, Microphone-in, or Headphone-out port
(1) Headphone port
Rear: (1) Line-out
(1) Line-in (retaskable as a Microphone Input)
Internal speaker (standard)
Yes
Multi-streaming capable
Yes
Integrated Webcam and Microphone
Integrated webcam and microphone
Integrated 2 MP Full HD RGB webcam and microphone; maximum resolution of 1920 x 1080 (optional)
Integrated 2 MP Full HD RGB dual-facing webcam with IR sensor (user-facing) and microphone; maximum resolution of 1920 x 1080 (optional)
Ports/slots/bays
Specification
Ports
USB
(4) USB 2.0: (2) including 1 fast charging (front); (2) including wake from S4/S5 (rear)
(2) USB 3.1 Gen 1: (2) rear
(4) USB 3.1 Gen 2: (2) front, (2) rear
(2) USB Type-C 3.1 Gen 2, (1) front; (1) rear: optional
Video
(2) DisplayPort 1.2 (rear)
(1) configurable video port (rear) (optional)
Choice of DisplayPort 1.2, HDMI 2.0, VGA, or USB Type-C with alt mode display or 15 W output
Audio
(1) Front: Headphone
(1) Front: Universal Audio Jack with CTIA headset support
(1) Audio-out (rear)
(1) Audio-in (rear)
Network
(1) RJ-45 Ethernet port
Optional I/O
(1) Serial (RS-232) (rear)
Internal
(4) SATA storage connector
(1) M.2 PCIe x1 2230 (for WLAN)
(2) M.2 PCIe x4 2280/2230 combo (for storage)
(2) PCI Express v3.0 x1
(1) PCI Express v3.0 x16 (wired as x4)
Bays
(1) 9 mm Slim optical disc drive
(1) 133.35 mm (5.25 in) half-height drive
(1) SD Card Reader
(1) 6.35 cm (2.5 in) internal storage drive
(2) 8.89 cm (3.5 in) internal storage drive
The HP EliteDesk 800 G4 Workstation Edition can support a single graphics card up to 75 W. When configured with dual graphics cards, support is limited to 35 W for each.
Software/security
Specification
BIOS
HP BIOSphere Gen4 (requires Intel or AMD 8th Gen processors)
HP Sure Start Gen4
Available on HP EliteDesk equipped with Intel 8th generation processors.
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (for the methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module3
Pre-boot Authentication
Communication/Connectivity
Native Miracast Support
HP Wireless Wakeup
HP Value Add Software
HP ePrint Driver with JetAdvantage4
HP Hotkey Support – CMIT
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and Internet access)
HP Noise Cancellation Software
HP Velocity
Microsoft products
Buy Office
Manageability
HP Driver packs (available for download)
HP Softpaq Download Manager (SDM)
HP System Software Download Manager (SSM) (available for download)
HP BIOS Config Utility (BCU) (subscription required)
HP Client Catalog (available for download)
HP Manageability & Integration Kit (MIK) (available for download)
Ivanti Management Suite (subscription required)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client security software
HP Client Security
HP Security Manager (including Credential Manager and Password Manager)
HP DriveLock
HP Password Manager
HP WorkWise (requires Bluetooth) (Available as a free download on the App Store and Google Play)
HP PhoneWise
HP Sure Run (available on HP Elite products equipped with 8th generation Intel or AMD processors)
HP Sure Recover (available on HP Elite products equipped with 8th generation Intel or AMD processors)
HP Sure Click (available on select HP platforms and supports Microsoft Internet Explorer, Google Chrome, and Chromium. Supported attachments include Microsoft Office (Word, Excel, PowerPoint) and PDF files in read only mode.)
Microsoft
Microsoft Defender
Software security (standard)
Trusted Platform Module (TPM) 2.0 (Infineon SLB9670) (Common Criteria EAL4+ certified)
Convertible to FIPS 140-2 Certified mode (TPM 2.0 is not available for Win 7 32-bit). Restrictions apply; contact account manager for more details.
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Hardware security
SATA 0,1 port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Solenoid lock and Intrusion sensor
Integrated hood sensor
Serial, parallel, USB enable/disable (via BIOS)
RAID configurations (optional and does require a second hard drive)
Optional USB port disable at factory (user configurable via BIOS)
Removable media write/boot control
Power-on password (via BIOS)
Setup password (via BIOS)
Chassis padlocks and cable lock devices supported
Intel Identify Protection Technology (IPT)
Models configured with Intel Core processors have the ability to utilize advanced security protection for online transactions. IPT, used in conjunction with participating web sites, provides double identity authentication by adding a hardware component in addition to the usual user name and password. IPT is initialized through an HP Client Security module.
3Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
4Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds vary.
Power supply
Specification
80 PLUS Gold
500 W active PFC
87/90/87% efficient at 20/50/100% load (115 V)
80 PLUS Platinum
250 W active PFC
90/92/89% efficient at 20/50/100% load (115 V)
91/93/90% efficient at 20/50/100% load (230 V)
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50 - 60 Hz
Operating line frequency
47 - 63 Hz
Rated input current
500 W less than or equal to 6 A
250 W less than or equal to 3 A
DC output
+12 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 120 Vac with the ground wire disconnected, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 120 Vac with the ground wire intact with normal polarity, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
70 mm variable speed
Power cord length
1.83 m (6.0 ft)
External power adapter
Internal power supply
Physical specifications
Specification
Chassis (W x D x H)
154.94 x 370.84 x 365.76 mm (6.1 x 14.6 x 14.4 in)
System volume
1,269 cu in
20.8 L
Maximum supported weight (desktop orientation)
34.93 kg (77 lb)
Packaging (W x D x H)
298.96 x 478.02 x 516.89 mm (11.77 x 18.82 x 20.35 in)
Shipping weight
11.34 kg (25 lb)
Environmental
Specification
ENERGY STAR
Certified models available
EPEAT
Registered where applicable/supported
Registration status varies by country/region.
Low halogen (chassis, all internal components, and modules)
External power supplies, power cords, cables, and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
TAA compliance
TAA compliant models available
Operating conditions
Operating: 5°C-45°C
Non-operating: -40°C-66°C
Relative humidity (at maximum inlet temperature)
Operating: 5% to 90%
Non-operating: 5% to 90%
Maximum altitude (unpressurized)
Operating: 5,000 m
Non-operating: 50,000 ft. (15,240 m)
