HP Pavilion x360 - 15-cr0064st Product Specifications
4CD96UA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Video graphics
Intel® UHD Graphics 620
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data Transfer Only); 1 HDMI; 1 headphone/microphone combo
35.8 x 24.3 X 1.9 cm
2.07 kg
45 W AC power adapter
3-cell, 48 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
B&O PLAY, dual speakers
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP ePrint; HP Games by WildTangent; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Pre-installed software
Netflix
