HP ProDesk 400 G5 Microtower Business PC Specifications
Product image
Figure : HP ProDesk 400 G5 Microtower Business PC
Operating systems
Specification
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.
Windows 10 Pro 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (Other)
FreeDOS 1.2
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Specification
Intel Core i7-8700 processor
65 W
Up to 4.6 GHz maximum Turbo Frequency (3.2 GHz base frequency)
12 MB cache, 6 cores, 12 threads
Intel UHD Graphics 630
DDR4 memory up to 2666 MT/s data rate
Intel Core i7+ 8700 processor (Core i7 and Intel Optane)
65 W
Intel Core i5-8600 processor
65 W
Up to 4.3 GHz maximum Turbo Frequency (3.1 GHz base frequency)
9 MB cache, 6 cores, 6 threads
Intel Core i5+ 8600 processor (Core i5 and Intel Optane)
65 W
Intel Core i5-8500 processor
65 W
Up to 4.1 GHz maximum Turbo Frequency (3.0 GHz base frequency)
Intel Core i5+ 8500 processor (Core i5 and Intel Optane)
65 W
Intel Core i3-8300 processor
62 W
3.7 GHz base frequency
8 MB cache, 4 cores, 4 threads
DDR4 memory up to 2400 MT/s data rate
Intel Core i3-8100 processor
65 W
3.6 GHz base frequency
6 MB cache, 4 cores, 4 threads
Intel Pentium Gold G5600 processor
54 W
3.9 GHz base frequency
4 MB cache, 2 cores, 4 threads
Intel Pentium Gold G5500 processor
54 W
3.8 GHz base frequency
Intel Pentium Gold G5400 processor
54 W
Intel UHD Graphics 610
Intel Celeron G4900 processor
54 W
2 MB cache, 2 cores, 2 threads
Intel B360
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Optane memory (cache) is sold separately.
Memory
Specification
DDR4-2666
Maximum: 32 GB
Number of slots: (2) DIMM (both slots are customer accessible/upgradeable)
Up to 2666 MT/s
Configurations
4 GB total system memory (4 GB x 1)
8 GB total system memory (4 GB x 2)
8 GB total system memory (8 GB x 1)
16 GB total system memory (8 GB x 2)
16 GB total system memory (16 GB x 1)
32 GB total system memory (16 GB x 2)
Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.
Memory modules support data transfer rates up to 2666 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
All memory slots are customer accessible/upgradeable.
Graphics
Specification
Intel HD Graphics (Integrated)
Intel Core i7 processor
Intel Core i5 processor
Intel Core i3 processor
Intel Pentium Gold G5500T processor
Intel Pentium Gold G5400T processor
Intel Celeron G4900T processor
Optional (Discrete)
AMD Radeon R7 430, 2 GB 2 DisplayPort (DP)
AMD Radeon R7 430, 2 GB DP and VGA
AMD Radeon RX550, 4GB FH 2DP and HDMI
Adapters and cables
Specification
Adapters
HP DisplayPort to DVI-D adapter
HP DisplayPort to HDMI True 4K adapter
HP DisplayPort to VGA adapter
HP USB to Serial Port adapter
HP Type-C to DisplayPort adapter
Cables
HP USB-C to USB 3.0 cable
HP DisplayPort cable
HP DVI cable
Storage
Specification
SATA drives
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in)
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
2 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
Solid State Hybrid drives (SSHD)
500 GB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in), 8 GB Hybrid
1 TB, 5.4 K rpm, SATA 6.0 Gb/s, 6.35 cm (2.5 in), 8 GB Hybrid
Self-Encrypting drives (SED HDD)
500 GB, 7.2 K rpm, SATA 2.0 (3.0 Gb/s), 6.35 cm (2.5 in), SED Opal 2
500 GB, 7.2 K rpm, 6.35 cm (2.5 in), SED FIPS
Solid State Drives (SSD)
256 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
512 GB, SATA 3 (6.0 Gb/s), 6.35 cm (2.5 in), TLC SSD
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED Opal 2
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), TLC SED Opal 2
256 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), SED FIPS
512 GB, SATA (6.0 Gb/s), 6.35 cm (2.5 in), SED FIPS
PCIe NVMe TLC SSD drives
128 GB M.2 2280 PCIe NVMe SSD
256 GB M.2 2280 PCIe NVMe SSD
512 GB M.2 2280 PCIe NVMe SSD
128 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe TLC SSD
512 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe Self Encrypted Opal 2 TLC SSD
512 GB M.2 2280 PCIe NVMe Self Encrypted Opal 2 TLC SSD
Optical disc drives (optional)
HP 9.5 mm (0.37 in) Slim DVD-ROM
HP 9.5 mm (0.37 in) Slim DVD-Writer
HP 9.5 mm (0.37 in) Slim Blu-ray Writer
Media Card Reader (optional)
SD 3.0 with 4-in-1 Interface
Supports SD, SDXC, SDHC, UHS-I
Card sold separately.
For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Keyboards/pointing devices
Specification
Keyboards
HP PS/2 Business Slim Standalone Wired Keyboard
HP USB Business Slim Standalone Wired Keyboard
HP USB Business Slim Wired SmartCard CCID Keyboard
HP USB and PS/2 Washable Standalone Wired Keyboard
HP Premium Standalone Wireless Keyboard
HP Collaboration Wireless Keyboard
HP USB Collaboration Wired Keyboard
HP USB Conferencing Wired Keyboard
HP USB Wired Keyboard
Standalone Wired Keyboard Value
Mice
HP USB Universal Wired Mouse
HP PS/2 Mouse
HP USB Optical Mouse
HP USB Hardened Mouse
HP USB 1000dpi Laser Mouse
HP USB & PS/2 Washable Wired Mouse Standalone
HP USB Premium Wired Mouse
Combos
HP Premium Wireless Keyboard and Mouse
HP Premium USB Wired Keyboard and Mouse
HP Business Slim Wireless Keyboard and Mouse
HP USB Keyboard and Mouse Healthcare Edition
HP USB Keyboard and Mouse Wired Value
HP USB PS/2 Washable Keyboard and Mouse Wired
Availability might vary by country/region.
Networking/communications
Specification
Ethernet (RJ-45)
Integrated
Realtek RTL8111HSH-CG Gigabit Network Gbe Connection (standard)
Optional
Intel Ethernet I210-T1 PCIe x1 Gb Network Interface Card
Wireless LAN (WLAN) (optional)
Intel 9560 802.11ac 2x2 Wi-Fi with Bluetooth M.2 Combo Card non-VPro
Realtek RTL8821CE 802.11ac 1x1 with Bluetooth M.2 Combo Card
Realtek RTL8723DE 802.11b/g/n 1x1 with Bluetooth M.2 Combo Card
Wireless access point and Internet service required and not included. Availability of public wireless access points limited.
Audio/multimedia
Specification
Type
Conexant CX20632 Audio Codec (all ports are stereo)
2 W class D mono amplifier for the internal speaker only
(1) Headset connector supports a CTIA style headset and is retaskable as a Line-in, Line-out, Microphone-in, or Headphone-out port (front)
(1) Line-out (rear)
Internal speaker (standard)
Yes
Multi-streaming capable1
Yes
Ports/slots/bays
Specification
Ports
Standard
(4) USB 2.0: rear
(4) USB 3.1 Gen 1: (2) front, (2) rear
(1) USB 3.1 Gen 2: (1) rear: optional
(2) PS/2: optional
(1) DisplayPort 1.2 (rear)
(1) VGA (rear)
(1) Headset, front
(1) Audio line-in, rear
(1) Audio line-out, rear
(1) RJ-45 Ethernet
(2) Serial RS-232: optional
(2) PCI Express x1 (v3.0)
(1) PCI Express x16 (v3.0)
(3) SATA ports
Optional
(1) DisplayPort 1.2, HDMI 2.0, VGA, or USB Type-C with display output
(1) M.2 PCIe x1 2230 (for WLAN)
(1) M.2 PCIe x4 2280/2230 Combo (for storage)
Bays
(1) 6.35 cm (2.5 in) internal storage drive
(2) 8.89 cm (3.5 in) internal storage drive
MT can be configured with (1) 3.5 in internal storage drive bay or (1) 2.5 in internal storage drive bay and (1) 3.5 in internal storage drive bay.
(1) 0.9 cm (0.35 in) Slim optical disc drive (ODD)
(1) Secure Digital (SD) card reader
Software/Security
Specification
BIOS
HP BIOSphere Gen4
Requires Intel 8th generation processors.
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
HP LAN-WLAN Protection
Communication/Connectivity
Native Miracast Support
HP Wireless Wakeup
HP Value Add Software
HP ePrint Driver with JetAdvantage2
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and Internet access)
HP Noise Cancellation Software
HP Velocity
HP Sure Click (available on select HP platforms and supports Microsoft Internet Explorer and Chromium)
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP System Software Download Manager (SSM) (available for download)
HP BIOS Config Utility (BCU) (subscription required)
HP Client Catalog (available for download)
HP Manageability & Integration Kit (MIK) (available for download)
Ivanti Management Suite (subscription required)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client security software
HP Client Security Suite Gen 4 (requires Windows and Intel or AMD 8th generation processors)
HP Security Manager (including Credential Manager, HP Password Manager, and HP Spare Key)
HP Device Access Manager
HP WorkWise app (available as a free download on the App Store and Google Play)
HP PhoneWise (might not be available with HP Workwise)
Microsoft Defender
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Downgradeable to TPM 1.2
Convertible to FIPS 140-2 Certified mode
Removable media write/boot control
Power-on password (via BIOS)
Setup password (via BIOS)
SATA port disablement (via BIOS)
Serial, USB enable/disable (via BIOS)
Chassis padlocks and cable lock devices supported
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds vary.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power supply
Specification
80 PLUS Gold
180 W active PFC/80 PLUS Gold 87/90/87% efficient at 20/50/100% load (115 V)
310 W active PFC/80 PLUS Gold 87/90/87% efficient at 20/50/100% load (115 V)
80 PLUS Platinum
250 W active PFC/80 PLUS Platinum 90/92/89% efficient at 20/50/100% load (115 V), 91/93/90% efficient at 20/50/100% load (230 V)
Rated input current
250 W less than or equal to 3A
310 W less than or equal to 4A
180 W less than or equal to 2.3A
Operating voltage range
90 - 264 VAC
Rated voltage range
100 - 240 VAC
Rated line frequency
50 - 60 Hz
Operating line frequency
47 - 63 Hz
DC output
+12 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 264 Vac with the ground wire disconnected, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 264 Vac with the ground wire intact with normal polarity, as required for Non-patient electrical appliances and equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
70 mm variable speed
Power cord
1.83 m (6.0 ft)
Physical specifications
Specification
Chassis (W x D x H)
169.92 x 274.06 x 337.82 mm (6.69 x 10.79 x 13.3 in)
System volume
960 cu in
15.74 L
System weight
5.47 kg (12.06 lb)
Maximum supported weight (desktop orientation)
35 kg (77.16 lb)
Packaged (W x D x H)
389.89 x 297.94 x 499.11 mm (15.35 x 11.73 x 19.65 in)
Shipping weight
9.2 kg (20.28 lb)
Environmental
Specification
ENERGY STAR
Certified models available
EPEAT
Registered where applicable/supported
Registration status varies by country/region.
TAA compliance
TAA compliant models available
