Document ID: c06031196
Version: 1
Advisory: HP Engage One All-in-One System - Touching the Touchscreen Causes Screen Flicker
Release date : 23-May-2018
Last updated : 02-Aug-2018
DESCRIPTION
The touchscreen may flicker when touched. This occurs with BIOS version 00.02.02.
SCOPE
Systems:
  • HP Engage One All-in-One System
Configuration:
  • BIOS is version 00.02.02
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
HP Engage One All-in-One System BIOS (P30)
Version: 00.02.16 Revision: A
NOTE: A more recent version of this software may be available. Check for newer versions at: http://www.hp.com/drivers
Hardware platforms affected : HP Engage One All-in-One System
Support Communication Cross Reference ID : IA06031196
