HP LaserJet Managed E50045 - Order supplies, accessories, and parts
Ordering
Order supplies and paper
Order genuine HP parts or accessories
Order through service or support providers
Contact an HP-authorized service or support provider.
Order using the HP Embedded Web Server (EWS)
To access, in a supported Web browser on your computer, enter the printer IP address or host name in the address/URL field. The EWS contains a link to the HP SureSupply website, which provides options for purchasing Original HP supplies.
Supplies and accessories
In order to purchase toner cartridges, contact your managed service representative. Make sure that you know your product model number, which appears on the product label on the printer rear door.
Item
Cartridge number
Part number
Accessories
1 x 550-sheet paper feeder
Optional 550-sheet paper feeder
The printer supports up to three 1 x 550-sheet paper feeders.
Not applicable
F2A72A
Printer stand and cabinet
Optional stand with storage cabinet to support the printer
Recommended when using multiple optional paper feeders.
Not applicable
F2A73A
FIPS 500GB Hard-disk drive
Optional hard drive
Not applicable
B5L29A
1 GB DDR3 Memory DIMM
Optional DIMM for expanding the memory
Not applicable
G6W84A
HP Internal USB ports
Two optional USB ports for connecting third-party devices
Not applicable
B5L28A
HP Internal USB Port
HP Internal USB Ports accessory
Not applicable
F2A87A
HP Trusted Platform Module
Automatically encrypts all data that passes through the printer
Includes installation instructions
Not applicable
F5S62A
HP Jetdirect 2900nw Print Server
USB wireless print server accessory
Not applicable
J8031A
HP Jetdirect 3000w NFC/Wireless Accessory
For use in the Hardware Integration Pocket. The HP Jetdirect 3000w NFC/Wireless Accessory requires the HP Internal USB ports accessory (B2L28A). The J8031A can also be connected via the rear host USB port. in that case, the HIP is not used.
Wi-Fi direct accessory for “touch” printing from mobile devices
Not applicable
J8030A
Customer self-repair parts
Customer Self-Repair (CSR) parts are available for many HP LaserJet printers to reduce repair time. More information about the CSR program and benefits can be found at www.hp.com/go/csr-support and www.hp.com/go/csr-faq.
Genuine HP replacement parts can be ordered at www.hp.com/buy/parts or by contacting an HP-authorized service or support provider. When ordering, one of the following will be needed: part number, serial number (found on back of printer), product number, or printer name.
  • Parts listed as Mandatory self-replacement are to be installed by customers, unless you are willing to pay HP service personnel to perform the repair. For these parts, on-site or return-to-depot support is not provided under the HP printer warranty.
  • Parts listed as Optional self-replacement can be installed by HP service personnel at your request for no additional charge during the printer warranty period.
Item
Self-replacement options
Part number
Solid State Memory Drive kit
Replacement solid-state memory drive
Mandatory
5851-6415
Hard Disk Drive kit
Replacement hard-disk drive
Mandatory
5851-6417
FIPS HDD 500GB Kit (US government only)
Mandatory
B5L29–67903
USB Wireless Print Server kit
Replacement HP Jetdirect 2900nw Print Server
Mandatory
5851-6421
NFC Accessory kit
Replacement HP Jetdirect 3000w NFC/Wireless Accessory
Mandatory
5851-6429
1GB DDR3 Memory DIMM
Replacement memory DIMM
Mandatory
5851-6422
HP Internal USB Ports Kit
Replacement internal USB ports
Mandatory
B5L28–67902
Secure Hard Disk Drive kit
Replacement HP Secure High-Performance Hard Disk Drive
Mandatory
B5L29–67903
Transfer Roller Service Kit
Replacement transfer roller
Mandatory
F2A76-67905
Tray 1 Pick Up and Separation Roller Kit
Replacement rollers for Tray 1
Mandatory
F2A76-67906
Tray 2-x Roller Kit
Replacement rollers for Tray 2 , 3, 4, and 5
Mandatory
F2A76-67907
1x550-sheet paper feeder
Replacement paper feeder
Mandatory
F2A72–67901
Replacement printer stand and cabinet
Mandatory
F2A73–67901
