Use the following procedure to check for paper in all possible jam locations related to the optional 550-sheet paper feeders. When a jam occurs, the control panel displays an animation that assists in clearing the jam.
Open the lower-right door.Figure : Open the lower-right door
Gently pull out any jammed paper.Figure : Remove the jammed paper
Pull the tray completely out of the printer by pulling and lifting it up slightly.Figure : Remove the tray
Remove any jammed or damaged sheets of paper. Verify that the tray is not overfilled and that the paper guides are adjusted correctly.Figure : Remove the jammed paper
Remove any paper from the feed rollers inside the printer. First pull the paper to the left to release it, and then pull it forward to remove it.Figure : Remove the jammed paper
Close the lower-right door.Figure : Close the lower-right door
Reinsert and close the tray.Figure : Close the tray
Open the right door.Figure : Open the right door
Gently pull out any jammed paper from the pick up area.Figure : Remove the jammed paper
Close the transfer assembly.Figure : Close the transfer assembly
Push down on the green levers to release the jam-access cover.Figure : Press down on the green levers
Gently pull out any jammed paper. If the paper tears, make sure to remove all remnants.Figure : Remove the jammed paper
Close the jam-access cover, and then lower the transfer assembly.Figure : Close the jam-access cover
Close the right door.Figure : Close the right door
