    Fix Windows 10 Update Issues
    Are you working from home?
Document ID: c06022698
Version: 1
Advisory: HP EliteBook 840 G5 Healthcare Edition Notebook PC - Various Issues After Closing the Lid While HP Easy Clean Is Running
Release date : 17-May-2018
Last updated : 17-May-2018
DESCRIPTION
HP Easy Clean does not exit sanitization mode when you close the lid if the computer is configured to " Do nothing" when the lid gets closed. In that case the computer remains in sanitization mode and the touchscreen and clickpad remain disabled after the lid is reopened.
SCOPE
The information in this document applies to the following:
Computers:
  • HP EliteBook 840 G5 Healthcare Edition Notebook PC
Configuration:
  • The computer is configured to " Do Nothing" with the lid gets closed
RESOLUTION
Exit sanitization mode by pressing this key combination: Fn+[left ALT]+ L.
Hardware platforms affected : HP EliteBook 840 G5 Healthcare Edition Notebook PC
Support Communication Cross Reference ID : IA06022698
