    Fix HP Printer issue on macOS
HP Web Jetadmin - Back Up and Restore HP Web Jetadmin
Scripts for backing up and restoring HP Web Jetadmin are available. These scripts provide examples of the recommended method for backing up and restoring the HP Web Jetadmin settings and data, including the Microsoft SQL Server database. The WJABackupRestoreInstructions_<language_code>.txt file provides instructions for running the scripts. The scripts and instructions are available in the following directory:
C:\Program Files\HP Inc\Web Jetadmin 10\WJABackupRestore
