    Fix Windows 10 Update Issues
    Are you working from home?
HP Printers - No Connection after Router or Wi-Fi Settings Change
This document is for HP wireless printers connecting to a Wi-Fi network.
This document explains how to reconnect a previously installed wireless printer to the network if you changed your Internet Service Provider (ISP) or purchased a new router. When you change network settings such as the network name and password, you must also reconfigure the printer for those new settings.
When troubleshooting a connection to your wireless network, make sure you are connecting your printer to the router and not a wireless extender.
