HP Spectre - 13-af512tu Product Specifications
3PF59PA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
8 GB LPDDR3-2133 SDRAM (onboard)
Video graphics
Intel® UHD Graphics 620
512 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS micro-edge WLED-backlit touch screen with Corning® Gorilla® Glass NBT™ (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 2.0; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 1 VGA; 2 Thunderbolt™ 3 (Data Transfer up to 40 Gb/s, Power Delivery, DP1.2, HP Sleep and Charge)
Dimensions (W x D x H)
30.82 x 22.42 x 1.04 cm
Starting at 1.11 kg
65 W AC power adapter
4-cell, 43.7 Wh Li-ion polymer
Bang & Olufsen, dual speakers, HP Audio Boost
Windows 10 Pro 64
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
