    Fix Windows 10 Update Issues
    Are you working from home?
HP 14-inch Privacy Screen Filter Specifications
Product image
Figure : HP 14-inch Privacy Screen Filter
Specification
Features
Diminishes screen readability for anyone not seated directly in front of the notebook.
Retains use of camera, sensors, and interactive touchscreen and pen input.
Resists scratches and fingerprints.
Anti-glare and exact-fit
Apply and remove the filter with reusable adhesive tape.
Compatible notebook screen size (diagonal)
HP EliteBook 1040 G3 Notebook PC
Viewing angle
60°
Transmission
68%
Thickness
0.29 mm (0.01 in)
