Document ID: c05948679
Version: 1
Advisory: HP ENVY x2 - 12 - IMEI Number Changes With Replacement Motherboard, Will Not Match Number on Computer Case
Release date : 16-Mar-2018
Last updated : 19-Mar-2018
DESCRIPTION
If the motherboard has been replaced, the IMEI number etched on the case of the computer will no longer be valid. You will need to look up the new IMEI number.
SCOPE
Computers:
  • HP ENVY x2 - 12-e000 CTO
  • HP ENVY x2 - 12-e000na
  • HP ENVY x2 - 12-e001na
  • HP ENVY x2 - 12-e001nf
  • HP ENVY x2 - 12-e001tu
  • HP ENVY x2 - 12-e011nr
  • HP ENVY x2 - 12-e050na
  • HP ENVY x2 - 12-e051na
RESOLUTION
Locate the IMEI number as follows:
  1. Select SETTINGS > Network & Internet > Cellular.
  2. Select your mobile service provider then select Advanced Options.
  3. The IMEI number is displayed under Properties.
Hardware platforms affected : HP ENVY x2 - 12-e000 CTO, HP ENVY x2 - 12-e000na, HP ENVY x2 - 12-e001na, HP ENVY x2 - 12-e001nf, HP ENVY x2 - 12-e001tu, HP ENVY x2 - 12-e011nr, HP ENVY x2 - 12-e050na, HP ENVY x2 - 12-e051na
Support Communication Cross Reference ID : IA05948679
