HP Notebook - 15-bs767tx Product Specifications
3VM54PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ 520 Graphics (2 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
15.6" diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
802.11a/b/g/n (1x1) and Bluetooth® 4.0 combo
1 HDMI; 1 headphone/microphone combo; 1 RJ-45; 1 USB 2.0; 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
38 x 25.38 x 2.38 cm
Starting at 1.86 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
