    Windows 11 Upgrade Guide
Document ID: c05940601
Version: 1
Advisory: HP ENVY 12-E000 X2 Detachable PCs - Cellular Does Not Establish Connection When SIM Card Is Inserted During Sleep Mode
Release date : 02-Mar-2018
Last updated : 02-Mar-2018
DESCRIPTION
The cellular connection is not established. This occurs when a Sim card is inserted and/or switched while the computer is in Sleep mode and then resumes from Sleep mode.
SCOPE
The information in this document applies to the following:
Hardware:
  • Sim card
  • Sim card tray
Computers:
  • HP ENVY 12-e000 x2 Detachable PC series
Operating Systems:
  • Microsoft Windows 10 TH1 (Version 1507)
  • Microsoft Windows 10 RS3 (Version 1709)
  • Microsoft Windows 10 RS2 (Version 1703)
  • Microsoft Windows 10 RS1 (Version 1607)
  • Microsoft Windows 10 Pro (64-bit)
  • Microsoft Windows 10 Pro (32-bit)
  • Microsoft Windows 10 Mobile
  • Microsoft Windows 10 IoT (64-bit)
  • Microsoft Windows 10 Home (64-bit)
  • Microsoft Windows 10 Home (32-bit)
  • Microsoft Windows 10 Enterprise (64-bit)
  • Microsoft Windows 10 (32-bit)
RESOLUTION
To recover from this issue, perform the following steps:
  1. Insert a paper clip into the hole in the Sim card tray.
  2. Push gently to eject the Sim card.
  3. Reinsert the Sim card.
  4. The cellular connection will be restored.
    Figure : Steps to eject the Sim card
  1. Insert and paperclip and push gently
  2. Removing the SIM card
  3. Reinserting the SIM card
Hardware platforms affected : HP ENVY 12-e000 x2 Detachable PC series
Support Communication Cross Reference ID : IA05940601
