    Fix Windows 10 Update Issues
HP Enterprise - Access help instructions from the printer control panel
The printer control panel has a built-in Help system that explains how to use the features on each screen. Some Help screens open to a top-level menu where you can search for specific topics and browse through the menu structure. And some Help topics include animations that show specific procedures, such as clearing paper jams.
Access the Help system on the control panel
To open the Help system, select the Help button on the control panel. Control panel size and appearance vary by the printer model and the installed firmware (FutureSmart 3 or FutureSmart 4). The following examples show the location of the Help button on several different types of control panels.
If the control panel displays an error or warning message, select the Help button to open a topic that describes the problem. The topic also contains instructions to help solve the problem.
FutureSmart 3 Control Panels
FutureSmart 4 Control Panels
