HP Pavilion x360 - 11-ad035tu Product Specifications
3PU30PA
Intel® Celeron® N3350 (1.1 GHz base frequency, up to 2.4 GHz burst frequency, 2 MB cache, 2 cores)
4 GB DDR3L-1600 SDRAM (1 x 4 GB)
Video graphics
Intel® HD Graphics 500
500 GB 5400 rpm SATA
11.6" diagonal HD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI; 1 headphone/microphone combo; 3 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
29.5 x 20.15 x 1.93 cm
Starting at 1.3 kg
45 W AC power adapter
2-cell, 37.2 Wh Li-ion
Dual speakers; B&O PLAY; HP Audio Boost
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Orbit; HP Recovery Manager; HP Support Assistant; HP Sure Connect
