Integrated video is not available if a graphics card is installed.
Sound/Audio
Integrated audio
Audio Codec: ALC3863-CG
High Definition (Azalia) 5.1 channel audio support
The motherboard supports 5.1 surround sound. If the computer does not have the required audio jacks for a 5.1 configuration, additional hardware is required to use 5.1 surround sound.
Audio jack presence detection
An internal speaker is not included with integrated audio. External speakers or headphones are required to hear sound.
Integrated audio is not available if a sound card is installed.
Networking
Wireless LAN 802.11a/b/g/n/ac (1x1) and Bluetooth 4.2 M.2
Interface: M.2
Transmission standards: 802.11 a/b/g/n/ac
LAN: 1000BASE-T
Technology: Realtek RTL8161
Data transfer speeds: up to 10/100/1000 Mb/s
Transmission standards: 1000BASE-T Ethernet
Hard drives
1 TB
Interface: SATA
Rotational Speed: 7200 RPM
CD/DVD disc drive
DVD Writer
Data transfer rates up to 3,600 KB/s (CD read/write)
Data transfer rates up to 10,800 KB/s (DVD read/write)
Formats/Disc types
Write speeds
Read speeds
DVD
DVD-ROM SL
N/A
up to 8x
DVD-ROM DL
N/A
up to 8x
DVD+R SL
up to 8x
up to 8x
DVD+R DL
up to 6x
up to 8x
DVD-R SL
up to 8x
up to 8x
DVD-R DL
up to 6x
up to 8x
DVD+RW
up to 8x
up to 8x
DVD-RW
up to 6x
up to 8x
CD
CD-R
up to 24x
up to 24x
CD-RW
up to 10x
up to 24x
CD-ROM
N/A
up to 24x
Memory card reader
3-in-1 memory card reader
Figure : 3-in-1 memory card reader
Supports the following cards:
SD
SDHC
SDXC
Computer case
Chassis
Height: 41.7 cm (16.43 in) unpacked
Width: 19.2 cm (7.56 in) unpacked
Depth: 44.2 cm (17.41 in) unpacked
Weight: 17.6 Kg (38.80 lbs) unpacked
Power supply
Internal 500 W
500 W internal power supply
Active PFC Bronze efficiency
I/O ports
Top I/O ports
The configuration might vary depending on your model.
USB 3.0-Type C: 2
USB 3.0-Type A: 2
Headphone/Microphone: 1
Microphone: 1
Back I/O ports
The configuration might vary depending on your model (for example, if a dedicated graphics card is included). Any modifications or upgrades might change the configuration, port accessibility, and port functionality.
HP provides basic support for software that comes with the computer. For in-depth feature assistance, refer to the help section in the software or on the software vendor's Web site.
Software Category
Software Title
Recovery Manager: Program Reinstallation
Operating System
Microsoft Windows 10 Home (64-bit)
No
Entertainment, Music & Games
CyberLink Power Media Player
DTS Headphone:X
HP Audio Switch
Netflix
No
No
Yes
No
Productivity
Dropbox
HP Jumpstart
HP Jumpstart Apps
No
No
No
Imaging, Photography, Video & Film
HP ePrint
OMEN Command Center
No
Yes
Security
McAfee LiveSafe (12-month subscription)
No
Support
HP Documentation
HP PC Hardware Diagnostics UEFI
HP Support Assistant
Yes
Yes
Yes
Recovery
HP Recovery Manager
No
Browser
Microsoft Edge
No
This support document provides specifications and component images that reflect the original design intention for all PCs of this model. Under certain circumstances, a factory or service provider may install a component that meets or exceeds the listed specification and/or appears different than the image shown.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
