Document ID: c05923570
Version: 1
Advisory: HP Engage One All-in-One System - System Fails to Power On, Power LED Blinks 3-Red and 4-White Pattern
Release date : 05-Feb-2018
Last updated : 02-Aug-2018
DESCRIPTION
The system fails to power on:
  • Does not complete POST
  • The display is blank
  • Power LED blinks in 3-red, 4-white pattern
The issue occurs if the system power communication cable is plugged into the wrong USB-C port on the connectivity base.
SCOPE
Systems:
  • HP Engage One All-in-One System Model 141
  • HP Engage One All-in-One System Model 143
  • HP Engage One All-in-One System Model 145
I/O Connectivity Bases:
  • HP Engage One Basic I/O Connectivity Base
  • HP Engage One Advanced I/O Connuctivity Base
RESOLUTION
By design, the power and communication cable from the system must be plugged into the powered USB-C port on the connectivity base (see Figure 1 and Figure 2) in order for the system to power on.
NOTE: There are two USB-C ports on the connectivity bases but only one of them is a powered port. The powered port has a blue lightning bolt icon next to it.
FIGURE 1. Powered USB-C port on the Basic I/O Connectivity Base
FIGURE 2. Powered USB-C port on the Advanced I/O Connectivity Base
NOTE: There will be a cable lock present to secure the USB-C cable to the powered port. There will be no cable lock on the non-powered USB-C port.
Refer to the Maintenance and Service Guide for further details on connecting and configuring the I/O connectivity bases:
Hardware platforms affected : HP Engage One All-in-One System Base Model 141, HP Engage One All-in-One System Base Model 143, HP Engage One All-in-One System Base Model 145, HP Engage One All-in-One System Model 141, HP Engage One All-in-One System Model 143, HP Engage One All-in-One System Model 145, HP Engage One Basic I/O Connectivity Base, HP Engage One Retail Advanced I/O Connectivity Base
Support Communication Cross Reference ID : IA05923570
