HP LaserJet Pro MFP M28-M30a Printers - Blinking Lights
This document is for HP LaserJet Pro MFP M28a, M29a, M30a printers.
The following sections describe error conditions with blinking (flashing) lights displayed on the printer control panel, followed by solutions for each error. Find the blinking light pattern that displays on the control panel, and then follow the steps to resolve the issue.
     Example of the control panel buttons, icons, and lights
  1. ID Copy button
  2. Start Copy button
  3. Supply light
  4. Power button and light
  5. Attention light
  6. Cancel button
Attention and Supply lights blink, and the Ready light is on
There is an issue with the toner cartridge.
The Attention and Supplies lights are blinking
Service the printer
