HP LaserJet - Older HP printers with macOS drivers in Apple Software Update
This document applies to older HP LaserJet printer models compatible with macOS operating systems including High Sierra 10.13, Sierra 10.12, El Capitan 10.11, Yosemite 10.10, and Mavericks 10.9.
For newer printers (HP LaserJet Pro, HP LaserJet Enterprise, HP LaserJet Managed, HP PageWide, etc.), go to one of the following support documents:
For Deskjet, ENVY, Officejet, Photosmart, or PSC printers, go to macOS 10.13 High Sierra Compatible Printers or macOS 10.12, OS X 10.11, 10.10 Compatible Printers.
Get the driver
When upgrading an older printer with a macOS (Sierra 10.12 to macOS High Sierra 10.13 for example), drivers for a previously installed printer listed below will be automatically downloaded and installed from Apple Software Update.1,2 Use the information below to make sure the printer is compatible, and that you are using an install connection that the printer supports.
If the driver(s) is not automatically updated, or when installing an older HP LaserJet printer with a new MacOS 10.13 for the first time, you might need to manually download the driver(s) from Apple Software Update and then add the printer queue. Go to one of the following Apple support pages to download the driver:
AirPrint is not supported on the printers listed below unless otherwise noted. For alternative cloud printing and mobile solutions compatible with older HP LaserJets, go to www.hp.com/go/LaserJetMobilePrinting.
HP LaserJet
Legend
= USB connection
= Network connection
= Wireless connection
= AirPrint-capable
(P) = Print-only driver available in Apple Software Update (does not include fax or scan drivers).
(F) = Fax driver available in Apple Software Update (ASU).
(S) = Scan driver available in Apple Software Update (ASU).
HP LaserJet series
Install  connection5
HP TopShot LaserJet Pro M275 MFP (P)
6
HP LaserJet M1005 MFP (P)
3
HP LaserJet P1000
HP LaserJet P1005
3,4
HP LaserJet P1006
HP LaserJet P1007
HP LaserJet P1008
HP LaserJet P1009
3,4
HP LaserJet 1010
3
HP LaserJet 1012
3
HP LaserJet 1015
3
HP Color LaserJet CM1015 MFP (P)
HP Color LaserJet CM1017 MFP (P)
HP LaserJet 1022
HP LaserJet P1100
HP LaserJet Pro P1102
3,4
HP LaserJet P1100w
HP LaserJet Pro P1100w
HP LaserJet Pro P1102w
6
HP LaserJet series
Install  connection5
HP LaserJet M1120 MFP (P)
4
HP LaserJet M1130 MFP (P)(S)
HP LaserJet M1132 MFP (P)(S)
HP LaserJet M1136 MFP (P)(S)
3,4
HP LaserJet 1150
3
HP LaserJet 1160
3
HP LaserJet 1200
HP LaserJet Pro M1210 series (P)(S)
HP LaserJet Pro M1212nf MFP (P)(S)
HP LaserJet Pro M1214nf MFP (P)(S)
HP LaserJet Pro M1216nf MFP (P)(S)
HP LaserJet Pro M1217 MFP (P)(S)
HP LaserJet Pro M1218 MFP (P)(S)
HP LaserJet Pro M1213nf MFP (P)(S)
46
HP LaserJet 1300
HP Color LaserJet CM1310 MFP (P)(F)
HP Color LaserJet CM1312 MFP (P)(F)
4
HP LaserJet M1319 MFP (P)
3,4
HP LaserJet 1320
3
HP LaserJet 1320n
3
HP LaserJet series
Install  connection5
HP LaserJet P1500
HP LaserJet P1505
HP LaserJet P1505n
HP Color LaserJet CP1510
HP Color LaserJet CP1514
HP Color LaserJet CP1515
HP Color LaserJet CP1518
4
HP LaserJet M1522 MFP (P)(F)
HP LaserJet P1560
HP LaserJet P1566
HP LaserJet P1567
HP LaserJet P1568
3,4
HP LaserJet Pro P1600
HP LaserJet Pro P1606dn
6
HP LaserJet P2010
HP LaserJet P2014
3
HP LaserJet P2014n
HP LaserJet P2015
HP LaserJet P2015d
3
HP LaserJet P2015dn
HP LaserJet P2015n
HP LaserJet P2015x
HP Color LaserJet CP2020
HP Color LaserJet CP2025
4
HP LaserJet series
Install  connection5
HP LaserJet P2035
3,4
HP LaserJet P2050
HP LaserJet P2055
HP LaserJet 2100
HP LaserJet 2200
HP LaserJet 2300
HP LaserJet 2300L
3
HP Color LaserJet CM2320 MFP (P)(F)
4
HP LaserJet 2400
HP LaserJet 2410
3
HP LaserJet 2420
HP LaserJet 2430
HP Color LaserJet 2550
HP Color LaserJet 2600
HP Color LaserJet 2600n
3
HP Color LaserJet 2605
HP LaserJet series
Install  connection5
HP Color LaserJet 2700
HP LaserJet M2727 MFP (P)(F)
HP Color LaserJet 3000
HP LaserJet P3005
HP LaserJet P3010
HP LaserJet P3015
4
HP LaserJet M3027 MFP (P)
HP LaserJet M3035 MFP (P)
HP LaserJet 3300 MFP (P)
HP LaserJet 3320n MFP (P)
HP LaserJet 3310 MFP (P)
HP LaserJet 3330 MFP (P)
3
HP Color LaserJet 3500
3
HP Color LaserJet CP3505
HP Color LaserJet CP3520
HP Color LaserJet CP3525
4
HP LaserJet series
Install  connection5
HP Color LaserJet CM3530 MFP (P)
4
HP Color LaserJet 3550
3
HP Color LaserJet 3600
HP Color LaserJet 3700
HP Color LaserJet 3800
HP Color LaserJet CP4005
HP LaserJet P4010
HP LaserJet P4014
HP LaserJet P4015
4
HP Color LaserJet Enterprise CP4020
HP Color LaserJet Enterprise CP4025
4
HP LaserJet 4050
HP LaserJet 4050se
HP LaserJet 4050t
HP LaserJet 4050n
HP LaserJet 4050tn
HP LaserJet 4100
HP LaserJet 4100 MFP (P)
HP LaserJet series
Install  connection5
HP LaserJet 4200
HP LaserJet 4200L
HP LaserJet 4240
HP LaserJet 4240n
HP LaserJet 4250
HP LaserJet 4250L
HP LaserJet 4300
HP LaserJet M4345 MFP (P)
4
HP LaserJet 4345 MFP (P)
HP LaserJet 4350
HP LaserJet 4350L
HP Color LaserJet Enterprise CP4520
HP Color LaserJet Enterprise CP4525
4
HP Color LaserJet 4600
HP Color LaserJet 4610n
HP Color LaserJet 4650
HP Color LaserJet 4700
HP LaserJet series
Install  connection5
HP Color LaserJet 4730 MFP
HP Color LaserJet CM4730 MFP (P)
HP LaserJet M5025 MFP (P)
HP LaserJet M5035 MFP (P)
HP LaserJet 5100
HP LaserJet 5200
HP LaserJet 5200L
HP LaserJet 5200LE
HP LaserJet 5200LX
3
HP Color LaserJet 5500
HP Color LaserJet 5550
HP Color LaserJet CP6015
4
HP Color LaserJet CM6030 MFP (P)
HP Color LaserJet CM6040 MFP (P)
4
HP CM8000 Color MFP (P)
HP CM8050 Color MFP (P)
HP CM8060 Color MFP (P) (Edgeline)
HP LaserJet series
Install  connection5
HP LaserJet 8150
HP LaserJet 9000
HP LaserJet 9000 MFP (P)
HP LaserJet 9040
HP LaserJet 9050
HP LaserJet 9040 MFP (P)
HP LaserJet 9050 MFP (P)
4
HP LaserJet M9040 MFP (P)
HP LaserJet M9050 MFP (P)
HP Color LaserJet 9500
HP Color LaserJet 9500 MFP (P)
For driver support information for newer HP LaserJet Pro, HP LaserJet Enterprise, HP LaserJet Managed, or HP PageWide printers, go to one of the following support documents:
Scanning with older HP printers
While many newer HP multifunction printers support scanning, older HP LaserJet multifunction printers do NOT support scanning from HP Scan, Apple AirPrint, Image Capture, Preview, or Scan to PDF in OS X versions 10.9 and newer.
To scan with these older printers, use the control panel.
Footnotes
Footnotes
1
Internet connection required.
2
If the company restricts access to the internet or Apple Software Update, contact the system administrator.
3
No network support. Use a USB connection to scan and/or install.
4
Some printers do not support network or wireless installs. For these printers, use a USB connection. Select printers have wireless accessories which will enable a wireless install. Go to Printers that can use the HP 1200w NFC/Wireless Mobile Print Accessory.
5
Parallel and Serial port connections are NOT supported in Mac.
6
This printer is AirPrint-capable, and compatible with other mobile printing solutions. For more information, go to www.hp.com/go/LaserJetMobilePrinting.
