Samsung SCX-340x Laser MFP - Clearing Original Document Jams
The following procedure shows how to clear original document jams. When an original document jams in the document feeder, a warning message appears on the display.
To avoid tearing the document, remove the jammed document slowly and carefully.
To prevent document jams, use the scanner glass for thick, thin or mixed paper- originals.
Original paper jam in front of scanner
  • Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type.
  1. Open the document feeder cover.
    Figure : Document feeder cover, open
  2. Gently remove the jammed paper from the document feeder.
    Figure : Paper, remove
  3. Close the document feeder cover.
    Figure : Document feeder cover, close
Original paper jam inside of scanner
  4. Open the document feeder.
    Figure : Document feeder, open
  5. Grab the misfed paper, and remove the paper from the feed area by carefully pulling it.
  6. Close the document feeder.
    Figure : Document feeder, close
Original paper jam in exit area of scanner
  • This troubleshooting might not be available depending on model or optional goods.
  1. Remove any remaining pages from the document feeder.
  2. Close the stacker.
    Figure : Stacker, close
  3. Gently remove the jammed paper from the document feeder.
  4. Open the stacker.
    Figure : Stacker, open
