    Fix Windows 10 Update Issues
    Are you working from home?
Samsung ProXpress SL-M4030 Laser Printer - Loading Paper
This document provides instructions on how to load paper into the printer.
Load the print media you use for the majority of your print jobs in tray 1. Tray 1 can hold a maximum of 550 sheets of 75 g/m2 (20 lb) plain paper.
You can purchase optional trays and attach them below the standard tray to load an additional 550 sheets of paper for each tray. You can attach up to four additional trays.
Paper tray overview
To change the size of the paper in the tray, adjust the paper guides.
If you do not adjust the paper guides, it could cause paper jams or skewed output.
    Figure : Paper guides
  1. Paper length guide
  2. Paper width guide
  3. Paper limit mark
The paper-level indicator shows the amount of paper in the tray.
    Figure : Paper-level indicator
  1. Full
  2. Empty
