HP 24f 24-inch Display - Product Specifications
The HP 24f is a 61.0 cm (24 in) Display.
Figure : HP 24f Display
The HP 24f Display
Product numbers
2XN60AA, 3AL28AA
Technical specifications
LED feature
Specification
Display size
61.0 cm (24 in) diagonal
Display type
IPS with LED backlight, anti-glare
Panel active area
52.7 x 33.6 cm (20.7 x 11.7 in)
Brightness
300 nits
Color gamut
72%
Color support
Up to 16.7 million colors with the use of FRC technology
Pixel pitch
0.2745 x 0.2745 mm
93 PPI
Inputs
1 VGA
1 HDMI
HDCP supported on HDMI.
Viewing angle
Horizontal viewing angle: 178 degrees
Vertical viewing angle: 178 degrees
Scan range
Horizontal: 30-86 kHz
Vertical: 48-75 Hz
Recommended resolution (H x V)
1920 x 1080 at 60 Hz (FHD)
Full high-definition (FHD) content required to view FHD images.
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
5 ms gray-to-gray (GtG)
Typical: 14 ms GtG
Maximum: 28 ms GtG
Actual performance might vary.
Power consumption
22 Watts maximum
Tilt
-5 to +25 degrees
Power supply
External
Dimensions
W x D x H (unpacked):
54.1 x 18.0 x 40.9 cm (21.3 x 7.1 x 16.1 in)
Unpacked: 2.8 Kg (6.26 lbs)
