Samsung ML-1630 Laser Printer - Loading Paper
This document provides instructions on how to load paper into the printer for the Samsung Xpress SL-M3015 Laser Printer.
Load the print media you use for the majority of your print jobs in the tray. The tray can hold a maximum of 100 sheets of 75 g/m2 (20 lb bond) plain paper.
Illustrations in this user’s guide may differ from your printer depending on the model and options installed.
Loading paper in the tray
Use the following steps to load paper into the tray.
  1. Press the tray open button, then the tray pops out. Pull the tray completely out.
    Figure : Example of pressing tray open button to remove tray
    When the tray does not close properly, pull the tray half way out and try again.
  2. Place paper with the side you want to print facing down.
    Figure : Example of placing paper desired print side down
  3. Align the tray with the slot, and slide it into the printer.
    Figure : Example of aligning tray with slot
  4. After loading paper, set the paper type and size for the tray. See Software section for PC-printing.
    You can load previously printed paper. The printed side should be facing up with an uncurled edge at the rear. If you experience problems with paper feed, turn the paper around. Note that print quality is not guaranteed.
Changing the size of the paper in the tray
To load longer sizes of paper, such as Legal-sized paper, you need to adjust the paper guides to extend the paper tray. To change the tray size to other size, you must adjust the paper length guide properly.
    Figure : Example of adjusting the paper guides
  1. Paper length guide
  2. Paper width guide
Use the steps to change the paper size in the tray:
  1. Adjust the paper length guide to the desired paper length. It is preset to Letter or A4 size depending on the country. To load another size, hold the lever and move the length guide to the corresponding position.
    Figure : Example of adjust the paper length guide
    • The tray is preset to Letter or A4 size, depending on your country.
    • For example, if you want to change the size to Letter, hold the lever at the back of the tray, and rotate the lever clockwise.
      Figure : Example of changing paper size
  2. After inserting paper into the tray, while pinching the paper width guide as shown, move it toward the stack of paper until it lightly touches the side of the stack. Do not press the guide too tightly to the edge of the paper; the guide may bend the paper.
    Figure : Example of inserting paper into tray
    • Do not push the paper width guides far enough to cause the materials to warp.
    • If you do not adjust the paper width guides, it may cause paper jams.
      Figure : Example of properly adjusting paper width guides
