HP ZBook 14u G5 Mobile Workstation Specifications
Product image
Figure : HP ZBook 14u G5 Mobile Workstation
Feature
Preinstalled
Windows 10 Pro 641
Windows 10 Home 641
FreeDOS 1.2
Supported
Windows 10 Enterprise 641(available with a Volume Licensing Agreement)
1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Intel Core i7-8650U
1.9 GHz
8 MB cache and 4 cores
Up to 4.2 GHz with Intel Turbo Boost Technology
Intel Core i7-8550U
1.8 GHz
Up to 4.0 GHz with Intel Turbo Boost Technology
Intel Core i5-8350U
1.7 GHz
6 MB cache and 4 cores
Up to 3.6 GHz with Intel Turbo Boost Technology
Intel Core i5-8250U
1.6 GHz
Up to 3.4 GHz with Intel Turbo Boost Technology
Intel Core i5-7300U
2.6 GHz
3 MB cache and 2 cores
Up to 3.5 GHz with Intel Turbo Boost Technology
Intel Core i5-7200U
2.5 GHz
Up to 3.1 GHz with Intel Turbo Boost Technology
Intel Kaby Lake chipset integrated with processor
Intel Core i5/Core i7 with vPro technology capable (optional)
Intel Virtualization Technology (Intel VT)
Intel Active Management Technology (iAMT)
For Windows operating system only.
Future virtual appliances applications dependent on third-party software and compatibility to be determined.
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Intel Turbo Boost is based on maximum GHz for a single core.
Graphics
Feature
Integrated
Intel UHD Graphics 630
High-definition (HD) content is required to view high definition images.
Discrete
AMD Radeon Pro WX 3100 (2 GB dedicated GDDR5)
Supports up to three independent displays via internal LCD Panel, system DisplayPort, system VGA, or using the HP UltraSlim Docking Station DisplayPort and VGA ports (sold separately).
Microsoft DirectX 12 (Shader Model 5.0) and OpenGL 4.4 capable
AMD Enduro Technology supported
Displays
Feature
Internal
35.56 cm (14.0 in) diagonal LED backlit FHD UWVA eDP anti-glare (1920 x 1080)
35.56 cm (14.0 in) diagonal LED backlit FHD UWVA eDP with PSR anti-glare (1920 x 1080)
35.56 cm (14.0 in) diagonal Touch LED-backlit FHD UWVA eDP (1920 x 1080)
35.56 cm (14.0 in) diagonal Touch LED-backlit FHD UWVA eDP with PSR, anti-glare and SureView Privacy filter (1920 x 1080)
35.56 cm (14.0 in) diagonal LED backlit UHD UWVA eDP with PSR (3840 x 2160)
External
Up to 30-bit (2^30) per pixel (deep color with a total of 1,073,741,824 color variations)
Supported
DisplayPort (DP) with Multi-stream Transport (MST) (supported resolutions)
Up to UHD 3840 x 2160 with 24/30-bit color depth at 60 Hz
WUXGA (1920 x 1200) monitors, with 24/30-bit color depth up to 120 Hz
DVI-D
DVI (single link) support requires a DP-to-DVI adapter (sold separately)
Dual-link DVI is supported with an active USB powered adapter (sold separately)
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage and drives
Feature
Primary storage bay
M.2 SATA SED SSD
512 GB SATA-3 SS TLC FIPS-140-2 Solid State Drive
HP Z Turbo Drive (NVMe PCIe SSD)
256 GB PCIe Gen 3x4 TLC Solid State Drive
512 GB PCIe Gen 3x4 TLC Solid State Drive
1 TB PCIe Gen 3x4 TLC Solid State Drive
256 GB PCIe Gen 3x4 TLC Opal 2 Solid State Drive
512 GB PCIe Gen 3x4 TLC Opal 2 Solid State Drive
256 GB PCIe Gen 3x4 MLC Solid State Drive
512 GB PCIe Gen 3x4 MLC Solid State Drive
1 TB PCIe Gen 3x4 MLC Solid State Drive
Drive controllers
M.2 Storage Bay (SATA)
SATA-3 for SSD
HP Z Turbo Drive
PCIe NVMe SSD
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Specification
Standard
32 GB DDR4 1.2 V non-ECC SDRAM (transfer rates up to 2400 MT/s)
(2) SODIMM slots supporting dual-channel memory
4 GB, 8 GB, and 16 GB SODIMMs
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory channels
Maximum
Up to 32 GB
Optional 16 GB SODIMMs in 2 slots
Maximum memory capacities assume Windows 64-bit operating systems or Linux. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports/slots
Ports
Left side
(1) USB 3.0 charging port
(1) Security lock slot
Right side
(1) USB 3.1 Gen 1
(1) USB 3.0 port
(1) Headphone/microphone combo jack
(1) RJ-45/Ethernet port
(1) Side docking connector
(1) Power connector
Digital media slots
(1) Integrated SD flash media slot
Supports next generation Secure Digital (SD), and backward compatible to SDHC and SDXC.
(1) Integrated smart card reader
Audio/multimedia
Feature
Audio
Bang & Olufsen audio
Integrated stereo speakers
Integrated microphone (dual-microphone array when equipped with optional webcam)
Button for volume mute
Function keys for volume up and down
Combo microphone-in/stereo headphone-out jack
720 HD webcam with IR (optional near infrared imaging)
Microsoft Hello certification
Microsoft Skype for Business
HD format (widescreen 16:9)
Supports videoconferencing and still image capture
High quality fixed focus lens
Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Keyboard/pointing devices/buttons/function keys
Feature
Keyboard
General features
Optional backlit keyboard
Function key control to toggle backlit brightness setting: off/full/half brightness
Spill-resistant with drain (thin layer of Mylar film under the keyboard)
86-key compatible keyboard
U.S. and International key layouts available
Full-pitch key layout
Editing keys
Both left and right control and alt keys
Function keys
18.7 x 18.4 mm key pitch (center-to-center spacing)
Hot keys for instant access to power conservation and brightness
Pointing devices
Point stick with two additional point stick buttons
Image sensor clickpad for enhanced performance and improved precision on scroll and gesture.
Buttons
Share/present
Call answer
Call end
Function keys
F1 - Display switching
F2 - Blank or SureView
F3 - Brightness down
F4 - Brightness up
F5 - Audio mute
F6 - Volume down
F7 - Volume up
F8 - Microphone mute
F9 - Backlit toggle
F10 - Numlk
F11 - Wireless
F12 - Calendar
Networking/communication
Feature
Communications
Integrated Intel I219-LM Gigabit Network Connection (vPro configurations)
Integrated Intel I219-V Gigabit Network Connection (non-vPro configurations)
The term 10/100/1000 or Gigabit Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Broadband Wireless (WWAN)
Requires a Windows operating system (not available in all countries/regions)
Factory configurable only
Integrated Bluetooth
Combined with the supported wireless LAN option
802.11 Wireless LAN
Intel Dual Band Wireless-AC 8265 802.11 a/b/g/n/ac (2x2) WiFi with Bluetooth 4.2 Combo Adapter (vPro)
Intel Dual Band Wireless-AC 8265 802.11 a/b/g/n/ac (2x2) WiFi with Bluetooth 4.2 Combo Adapter (non-vPro)
Wireless cards are optional or add-on features. Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the workstation to communicate with other 802.11ac WLAN devices.
Wireless WAN - Mobile Broadband (optional)
HP lt4120 Qualcomm Snapdragon X5 LTE Mobile Broadband Module
HP It4132, LTE/HSPA+ 4G Mobile Broadband Module
HP hs3210 HSPA+ Mobile Broadband Module
WWAN use requires separately purchased service contract. Check with service provider for coverage and availability. Connection speeds varies due to location, environment, network conditions, and other factors. 4G LTE not available on all products, and in all countries/regions.
Near Field Communications (NFC)
HP Module with NXP NFC Controller NPC100
Secure, integrated wireless LAN and wireless WAN options supports the latest industry standards.
Software/security
Specification
BIOS
HP BIOSphere Gen3 (requires Intel 7th generation processors)
HP Sure Start Gen3 (requires Intel 7th generation processors)
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
Multi media
Cyberlink Power Media Player
Communication/connectivity
HP Mobile Connect Pro
Only available on preconfigured devices with WWAN.
Native Miracast support
HP LAN-WLAN Protection
HP MAC Address Manager (select models only)
HP Wireless Wakeup (select models only)
HP SureConnect
HP Value add software
HP 3D DriveGuard
HP ePrint Driver with JetAdvantage2
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Performance Advisor
HP Remote Graphics Software
HP Velocity
Microsoft products
Buy Office
Bing Search
Skype (not available in China)
Manageability
HP Driver packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft SCCM (available for download)
HP Image Assistant
LANDESK Management (subscription required)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client Security software
Microsoft Defender (opt in and internet connection required for updates)
HP WorkWise app (available as a free download on Google Play)
HP Client Security Suite Gen3 (requires Windows and Intel 7th generation processors)
HP Security Manager (including Credential Manager and Password Manager)
HP Fingerprint Sensor
HP Device Access Manager
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP Fingerprint Reader
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Workstation ISV certifications
Go to the Workstation ISV Certifications webpage to see current certifications
Other standard security features
Integrated Smart Card Reader
One-Step Logon
Security lock slot
Support for Intel AT
Optional security features
HP Fingerprint sensor
Absolute Data Protect with GPS tracking (requires HP Mobile Broadband Module)
The Absolute Data Protect agent is shipped turned off, and must be activated by customers when they purchase a subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S.
1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.
HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power
Power supply
HP 65W Slim Smart AC Adapter
Primary battery
HP 3-cell Long Life Polymer Battery (50 WHr)
Battery life
Battery life up to 10 hours
Battery life varies depending on the product model, configuration, loaded applications, features, use, wireless functionality, and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Power conservation
AMD Polaris technology
Hibernation
Standby
ACPI compliance
Physical specifications
Dimensions (W x D x H)
326.14 x 234.19 x 18.03 mm (12.84 x 9.22 x 0.71 in)
Height varies depending upon where on the workstation the measurement is made.
1.48 kg (3.26 lb)
Weight varies by configuration and components. Weight includes 3 cell 46 Whr battery, without hard drive and with 256 GB Z Turbo Drive (PCIe SSD).
Environmental
Feature
Certifications
US ENERGY STAR (select models only)
Configurations of the HP ZBook 14u G5 that are ENERGY STAR certified are identified as HP ZBook 14u G5 ENERGY STAR on HP websites.
Low Halogen
External power supplies, power cords, cables and peripherals are not low halogen. Service parts obtained after purchase might not be low halogen.
IT ECO declaration
EPEAT Gold registered where applicable (registration varies by country/region)
This product has received or is in the process of being certified to the the approvals and might be labeled with one or more of these marks.
Planned industry standard certifications
UL
CSA
FCC compliance
ICES
Australia/NZ A-Tick compliance
CCC
Japan VCCI compliance
KC
BSMI
CE marking compliance
MIL STD
Stand-alone power requirements (AC power)
Nominal operating voltage
19.5 V DC at 3.3 A
Average operating power (AMD FirePro Graphics)
16.8 W (Windows 10 64-bit)
Maximum operating power (NVIDIA Quadro Graphics)
< 65 W
Temperature
Operating
0° to 35° C (32° to 95° F) (not writing optical)
5° to 35° C (41° to 95° F) (writing optical)
Non-operating
-20° to 60° C (-4° to 140° F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 15,000 ft)
