Samsung Laser Printer - Loading Originals
This document provides instructions on how to load originals into the printer for the Samsung SCX-4833, Samsung SCX-4835, Samsung SCX-5635, Samsung SCX-5637, Samsung SCX-5639, Samsung SCX-5737, Samsung SCX-5739 Laser Multifunction Printer series.
You can use the scanner glass or the document feeder to load an original for copying, scanning, and sending a fax.
Illustrations in this user’s guide may differ from your printer depending on the model and options installed.
