Document ID: c05854210
Version: 1
Advisory: HP ZBook x2 G4 Detachable Workstation - Specific Changed Function of Pen or Eraser Button May Not Work When Windows Ink Workspace Is Running
Release date : 07-Dec-2017
Last updated : 11-Dec-2017
DESCRIPTION
After users change a setting for Pen's Click or Eraser to Applications such as Sticky Notes, Sketchpad, or Screen Sketch in HP Create Control Panel, the system may not be able to open the application when clicking pen or using eraser button when Windows Ink Workspace is running.
SCOPE
Systems:
  • HP ZBook x2 G4 Detachable Workstation
Operating Systems:
  • Microsoft Windows 10 x64
RESOLUTION
To resolve this issue, close the Windows Ink workspace and then retry the pen or eraser button again. Alternatively, the users can open the application using the Start menu/screen, pin shortcuts to the taskbar, or Cortana.
Hardware platforms affected : HP ZBook x2 G4 Detachable Workstation
Support Communication Cross Reference ID : IA05854210
