Samsung CLX-8380 Color Laser MFP - Clearing Paper Jams
This document shows you how to clear a paper jam in the printer. When a paper jam occurs, a warning message appears on the display screen.
Refer to the table below to locate and clear the paper jam.
Message
Location of Jam
Go to:
Paper Jam in tray 1
Paper Jam in tray 2
Paper Jam in tray 2 (HCF)
Paper Jam in tray 3
Paper Jam in MP tray
In the paper feed area (tray 1, optional tray, or multi-purpose tray)
Paper Jam in exit area
In the fuser area
Paper Jam inside printer
In the paper inside the printer
Paper Jam at bottom of duplex path
Paper Jam at top of duplex path
Paper jam inside duplex path
In the duplex unit
Paper jam in front of finisher
In the stacker
Paper jam inside finisher
Paper jam inside finisher's duplex
In the stacker
In the stacker exit part
To avoid tearing the paper, pull the jammed paper out gently and slowly. Follow the instructions in the following sections to clear the jam.
