HP V190 18.5-inch LED Backlit Monitor Specifications
Product image
Figure : HP V190 18.5-inch LED Backlit Monitor
Panel
Specification
Display panel type
Twisted Nematic (TN)
Display size (diagonal)
18.5 inches
46.99 cm (18.5 in)
Panel active area (W x H)
409.8 x 230.4 mm (16.13 x 9.07 in)
Aspect ratio
16:9
Viewing angle (typical CR > 10)
90° horizontal
65° vertical
Brightness
200 cd/m2 (typical)
Contrast ratio
Static
600:1 (typical)
450:1 (minimum)
Dynamic Contrast Ratio (DCR)
10,000,000:1 (typical)
Dynamic Contrast Ratios during video playback only, depending on series of frames or time duration.
Response times
5.0 ms (on/off)
Pixel pitch
0.3 x.0.3 mm
Pixels Per Inch (PPI)
85
Default color temperature
Neutral (6500 K)
Backlight lamp life
30,000 hours minimum (to half brightness)
Panel bit depth
6-bit HiFRC
Color gamut coverage
NTSC
72%
sRGB
99%
Anti-glare panel
Yes
Flicker free
Yes
Low blue light mode
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu/OK
Information/Minus
Viewing Modes/Plus
Auto adjustment/Exit
Power
User-assignable function buttons
3 (6 options)
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution/timing
1366 x 768 at 60 Hz
Maximum/recommended resolution
1366 x 768 at 60 Hz
Preset graphic modes/supported resolutions
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1366 x 768 at 60 Hz
Pixel clock
110 MHz (maximum)
Vertical scan range
50 - 60 Hz
Horizontal scan range
30 - 70 kHz
Video/other inputs
Specification
Connector types
(1) VGA
(1) Power connector
Ergonomics
Specification
Color
Black
Monitor bezel & stand
Plug and play
Yes
Tilt range
-4° to +20° vertical
Security lock ready
Sold separately
Detachable base
Yes
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC at 50/60 Hz
Maximum power
12 W
Typical power
10.5 W
Energy saving/standby mode
0.5 W
Power cable length
1.83 m (6.0 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
43.92 x 22.30 x 34.52 cm (17.29 x 8.78 x 13.59 in)
Packaged
50.09 x 16.89 x 33.30 cm (19.72 x 6.65 x 13.11 in)
Head only
43.92 x 4.55 x 27.18 cm (17.29 x 1.79 x 10.70 in)
Unpacked
2.4 kg (5.29 lb)
Packed
3.4 kg (7.49 lb)
Head only
1.9 kg (4.19 lb)
What's in the box?
Specification
Monitor and accessories
AC power cord, 1.83 m (6.0 ft)
VGA cable 1.8 m (5.90 ft)
Documentation
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-34° to 60° C (-29.2° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Eco-label certifications & declarations
ENERGY STAR 7
EPEAT Gold (registration varies by country/region)
CEL Grade 2
CB
CCC
CEL
CECP
SEPA
WEEE
KC
KCC
PSB
ISC
VCCI
BSMI
Vietnam MEPS
ANZ MEPS
UL/CSA
FCC/ICES
S-Mark
E-Standby
EPA 7.0
