Samsung Laser Printers - Samsung Printer Center Basic Applications
The Samsung Printer Center allows you to manage all the printer drivers installed on your computer from a single integrated application. You can use the Samsung Printer Center to add and remove printer drivers, check the status of printers, update printer software, and configure printer driver settings.
This document shows you how to add a printer, install and use Easy Document Creator and Samsung Print Diagnostics, install a network PC fax, and install a scan driver.
The Samsung Printer Center is synchronized with the Devices and Printers list on the computer Control Panel.
