HP Pavilion - 15-ck024tx Product Specifications
2US77PA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Video graphics
NVIDIA® GeForce® MX150 (2 GB GDDR5 dedicated)
1 TB 5400 rpm SATA
15.6" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45; 1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
35.89 x 24.73 x 1.99 cm
Starting at 1.77 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion prismatic
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
