Samsung Printers - Update Firmware Using Samsung Printer Diagnostics
This document introduces the flow of steps when you select the Update firmware option in the Samsung Printer Diagnostics (SPD) application.
Update the firmware
You can update the printer firmware by selecting Advanced options on the main SPD screen.
Figure : Select Advanced options
In Advanced options, select Update firmware and read the notices.
Figure : Select the update firmware option
Select a connected printer
This screen lists the available printers. Choose the printer you want the application to check for firmware updates.
Figure : Select a printer
Check for updates
This screen displays the progress of the application checking for firmware updates.
Figure : Checking for firmware updates
Updating the firmware progress
If authentication is needed for a network printer that is getting a firmware update, an authentication dialog pops up. The ID and password needed are for SWS (SyncThru Web Service).
Figure : Authentication dialog box
Firmware update complete
When the firmware is updated successfully a screen displays with a checkered flag.
Figure : Successful update screen
If no new updates are available, a screen displays a blue circle with a check mark. If the update failed, a failed screen displays.
Figure : No updates and failed screens
Country: Flag Vietnam
