HP ENVY x360 - 15-bp108ca Product Specifications
1UG62UA
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
  • Intel® UHD Graphics 620
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI v2.0a; 1 headphone/microphone combo
Dimensions (W x D x H)
35.97 x 24.88 x 1.96 cm
2.03 kg
65 W AC power adapter
3-cell, 55.8 Wh Li-ion
Bang & Olufsen, dual speakers
HP Audio Switch; HP CoolSense; HP ePrint; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
Pre-installed software
Netflix
What's in the box?
Contents
Stylus pen (natural silver)
