    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 15-bs089nk Product Specifications
2WG26EA
Intel® Core™ i3-6006U (2 GHz, 3 MB cache, 2 cores)
4 GB DDR4-2133 SDRAM (1 x 4 GB)
Video graphics
  • AMD Radeon™ 520 Graphics (2 GB DDR3 dedicated)
  • Discrete
1 TB 5400 rpm SATA
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with numeric keypad
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
38 x 25.38 x 2.38 cm
2.1 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
Battery type note
User-replaceable battery
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
