HP PageWide Enterprise, HP PageWide Managed - Clear paper jams in Tray 3 (15.A3.yz, 15.12.A3, 15.12.D3)
Clear paper jams in Tray 3 - 15.A3.yz; 15.12.A3; 15.12.D3
When a jam occurs, the control panel displays an error message and an animation that assists in clearing the jam. Paper jams in Tray 3 can produce any of the following error codes:
  • 15.A3.yz
  • 15.12.A3
  • 15.12.D3
Follow these steps to clear the paper jam:
The procedure to clear paper jams from the 1x550-sheet tray with cabinet stand is the same as for the table-top 1x550-sheet tray. Only the table-top tray is shown here.
  1. Open the right door and the lower-right door.
    Figure : Open the door
  2. Gently pull out any jammed paper.
    Figure : Remove the jammed paper
  3. If no jammed paper is visible, remove the duplexer.
    Figure : Remove the duplexer
  4. Pull any jammed paper straight out.
  5. Reinstall the duplexer.
    Figure : Reinstall the duplexer
  6. Open the tray.
    Figure : Open the tray
  7. Remove the jammed paper from the feed rollers inside the printer. First pull the paper to the left, and then pull it forward to remove it.
    Figure : Remove any damaged paper
  8. Close the lower-right door and the right door, and then close the tray.
    Figure : Close the door
  9. If there are remaining pages still in the printer, instructions on how to clear the remaining pages will display on the control panel.
