Samsung ProXpress MFP SL-M4560, SL-M4562 - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge.
A toner cartridge has almost reached its estimated toner cartridge life.
  • The status LED and the toner-related message on the display indicate when each individual toner cartridges should be replaced.
  • The computer's Samsung Printing Status program window appears on the computer and displays which color cartridge is empty on toner, see Using Samsung Printer Status.
Check the type of the toner cartridge for your machine, see Available supplies.
  • Shake the toner cartridge thoroughly, it will increase the initial print quality.
  • Illustrations on this user’s guide might differ from your printer depending on its options or models. Check your printer type.
  • To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover it with a piece of paper, if necessary.
  • Do not touch the green area of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
  • Do not use sharp objects such as a knife or scissors to open the toner cartridge package. They might scratch the drum of the cartridge.
  • If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
Replacing the toner cartridge
  1. Open the front door.
    Figure : Example of opening the front door
  2. Unlock the toner cartridge.
    Figure : Example of unlocking the toner cartridge
  3. Pull on toner cartridge handle, and then remove from the printer.
    Figure : Example of pulling on toner, and then removing
  4. Remove the new toner cartridge from the box.
    Figure : Example of removing the new toner cartridge
  5. Remove all packaging materials from the new toner cartridge.
    Figure : Example of removing all packaging materials
  6. Remove the protective plastic tab from toner cartridge before installing the new toner cartridge.
    Figure : Example of removing the protective plastic tab
    Make sure to recycle all packaging materials.
  7. Install the toner cartridge back into the printer.
    Figure : Example of installing the toner cartridge
  8. Lock the toner cartridge back inside the printer.
    Figure : Example of locking the toner cartridge in place
  9. Close the front door.
    Figure : Example of closing the front door
