    Fix Windows 10 Update Issues
Document ID: c05779534
Version: 1
Advisory: Error "MicroSoft Visual C++ Runtime Library Assertion Failed" Appears When Installing Intel NIC Driver
Release date : 02-Oct-2017
Last updated : 03-Oct-2017
DESCRIPTION
The following error message appears when installing the Intel i219 NIC driver:
Microsoft Visual C++ Runtime Library Assertion Failed
The issue occurs when Chinese is selected as the language for Windows AND the username is also in Chinese. It does not occur if the language is anything other than Chinese or if the username is not Chinese.
SCOPE
Configuration:
  • Intel I219 NIC driver is version 12.15.25.6 (or later).
  • System OS and user account both are Chinese.
Computers:
  • HP EliteDesk 705 G3 Small Form Factor PC
  • HP RP5 Retail System Model 5810
Operating Systems:
  • Microsoft Windows 10
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
Intel I219 NIC Drivers for DTO Microsoft Win 10 -64bit
Version: 12.15.25.6712
Revision: A
NOTE: A more recent version of this software may be available. Check for newer versions at: http://www.hp.com/drivers
Hardware platforms affected : HP EliteDesk 705 G3 Small Form Factor PC, HP RP5 Retail System Model 5810
Support Communication Cross Reference ID : IA05779534
