Document ID: c05779531
Version: 1
Advisory: HP RP2 Retail System - The System May Hang and Display STOP Error xxxxxx9F When USB Devices Are Improperly Removed
Release date : 02-Oct-2017
Last updated : 02-Oct-2017
DESCRIPTION
Improper removal of some devices may cause the system to stop responding (hang). One such device that is known to cause the issue is a TP-Link wireless dongle used with TL-WN821N software. If the device is removed from the computer without using the approved ejection process the computer hangs displaying the following error code on a blue screen:
xxxxxx9F
SCOPE
USB Device:
  • TP-Link USB wireless LAN adapter
Systems:
  • HP RP2 Retail System Model 2000
  • HP RP2 Retail System Model 2000 (ENERGY STAR)
  • HP RP2 Retail System Model 2020
  • HP RP2 Retail System Model 2030
  • HP RP2 Retail System Model 2030 (ENERGY STAR)
Operating Systems:
  • Windows Embedded 7 POSready
RESOLUTION
Avoid the issue by using the proper procedure for removing the device:
  1. Click the Safely Remove Hardware and Eject Media icon in the task tray.
    Figure : Safely Remove Hardware and Eject Media
    Safely Remove Hardware and Eject Media in the task tray
  2. Select Eject 801.11n NIC.
  3. Wait until the Save to Remove Hardware message appears.
  4. Remove the TP-Link device.
HP recommends using this procedure to eject all USB devices.
Hardware platforms affected : HP RP2 Retail System Model 2000, HP RP2 Retail System Model 2000 (ENERGY STAR), HP RP2 Retail System Model 2020, HP RP2 Retail System Model 2030, HP RP2 Retail System Model 2030 (ENERGY STAR)
Support Communication Cross Reference ID : IA05779531
